wgb123
#1 Posted : Wednesday, September 30, 2009 7:24:22 AM(UTC)
wgb123
I have a Kenmore Oasis Washer with two problems.
1: the drain pump will not pump water out unless the drain hose is close to the floor. IE into a 5 gallon bucket.
I orderd a new pump.
2: The lid lock does not engage. It tries, you can hear it click about 5 times but then errors out. This just started today. The manual states to remove obstuction. There's nothing blocking the path for the lid lock.
sidfink43
#2 Posted : Thursday, October 1, 2009 3:30:01 PM(UTC)
sidfink43
The likely problem is the lock has failed. Here is the service manual which will show you how to trouble shoot it.
https://secured.whirlpoo...73421b/$FILE/8178583.pdf
Good luck
