I can not get the halogen bulb out to replace it. It is protruding to little to grasp and pull out. Any ideas how to get it out safely? No help in the manual found and no help from KitchenAid on the phone. Please, help!!
The part number is for the bulb, WPL4452164.
The model number for the KitchenAid built-in oven/microwave is
KEMS307DWH6.
you might have to remove covering to get to bulb assembly
Originally Posted by: misterfixall  you might have to remove covering to get to bulb assembly I tried that but there is no cover to remove. The bulb is visible from the inside of the microwave and doesn't have a cover. Is there maybe a special device to pull out the halogen bulb without breaking it?
