ryangriffith
#1 Posted : Thursday, January 17, 2013 7:03:50 AM(UTC)
ryangriffith
I noticed the smell of burning electronics this morning about 20 min into the wash cycle. About 10 minutes later I heard a 'shorting' sound. After unplugging the unit, I took off the front access panel but did not note any water leakage or apparent melting. I plugged the unit back in and then restarted the cycle. It ran well for about 10 min and then flipped the breaker. I unplugged the unit again and opened the cover to its j-box and found that the neutral had melted through the wire nut and eventually grounded out on the jbox. The washer is wired to an appliance cord and plugged into a dedicated, grounded outlet on a separate circuit. Mainly, I want to know if there is any reason why I shouldn't cut out the damaged wiring and reconnect. Think this is a case of a loose connection or something wrong with the unit itself?
UPDATE - forgot to include the model #: FDBB2040FS1
ryangriffith attached the following image(s):
Simon / APP Team
#2 Posted : Thursday, January 17, 2013 12:26:30 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Just cut off the bad part of the wire and reconnect with new wire nut.
Make sure both wire nuts are tight.
Simon.
ryangriffith
#3 Posted : Thursday, January 17, 2013 6:50:53 PM(UTC)
ryangriffith
Thanks, Simon. That is what I had hoped for. So far so good.
Simon / APP Team
#4 Posted : Thursday, January 17, 2013 9:12:00 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
