driftman11
#1 Posted : Wednesday, January 16, 2013 5:56:59 PM(UTC)
driftman11
i had this oven torn down and didn't realize i had left the gray/white wire loose. I turned power back on and seen the wire spark then everything shut off and wont come back on. the gray/white wire was running from lower part of back upto the control panel and clipped in with like 5-6 other wires right beside the transformer. I was wondering if this would totally kill the board or would i be luckily enough that it merely shut the transformer down? visually the thermal fuse looks ok. I have yet to test it with meter tho. I really really need this oven to work if at all possible without replaceing the whole board.
Simon / APP Team
#2 Posted : Wednesday, January 16, 2013 7:07:32 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Try to reset the oven circuit breaker and if that's not going to help - replace the control board.
Bad news are, that it's discontinued. See if you can find it on the net.
Here are the breakdown diagrams and Control parts for Whirlpool RBD305PDB1 - AppliancePartsPros.com
Simon.
