i had this oven torn down and didn't realize i had left the gray/white wire loose. I turned power back on and seen the wire spark then everything shut off and wont come back on. the gray/white wire was running from lower part of back upto the control panel and clipped in with like 5-6 other wires right beside the transformer. I was wondering if this would totally kill the board or would i be luckily enough that it merely shut the transformer down? visually the thermal fuse looks ok. I have yet to test it with meter tho. I really really need this oven to work if at all possible without replaceing the whole board.
Groups: APP Team
