After reading similar posts on this error,I purchased the control board from this site and just replaced it today. The symptom is the same. I am reluctant to purchase the motor since it was also mentioned as a possible cause. :( Any help would be appreciated. Thank you.
The error code "E3" is showing because here have been problems with the motor wire harness connector on these washers. Either a loose or bent terminal in the molex connector. Another thing can be happen the terminals may be bent. check these things.
