danirowe9
#1 Posted : Wednesday, January 16, 2013 4:23:27 PM(UTC)
danirowe9
After reading similar posts on this error,I purchased the control board from this site and just replaced it today. The symptom is the same. I am reluctant to purchase the motor since it was also mentioned as a possible cause.
Any help would be appreciated. Thank you.
jenniferatkins
#2 Posted : Thursday, January 17, 2013 11:05:00 PM(UTC)
jenniferatkins
The error code "E3" is showing because here have been problems with the motor wire harness connector on these washers. Either a loose or bent terminal in the molex connector.
Another thing can be happen the terminals may be bent.
check these things.
