AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
je1456kwh02 Dual Wave III - fan goes on when door opened
Originally Posted by: Simon / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi, Bernie.
You need to replace the mounting bracket, one of the pins holding the switch broke off and the switch is moving instead of engaging.Unfortunately this part is no longer available. Unless you can figure out how to fix the switch to the bracket.
Simon. Thanks again, Simon. I will have to remove the cover and try to figure how to tape that switch in place if I can. I was considering if I should remove that whole assembly which holds the 3 switches but not sure if I would totally mess things up. Bernie
Originally Posted by: Bernie157 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks again, Simon. I will have to remove the cover and try to figure how to tape that switch in place if I can. I was considering if I should remove that whole assembly which holds the 3 switches but not sure if I would totally mess things up.
Bernie The microwave oven seems to have quit altogether now. I have order a new, smaller one online and hope to have it tomorrow. They are supposed to take the old one away. Bernie
Microwave Repair
