2 Pages<12
Bernie157
#11 Posted : Tuesday, January 22, 2013 12:24:06 PM(UTC)
Bernie157
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi, Bernie.
You need to replace the mounting bracket, one of the pins holding the switch broke off and the switch is moving instead of engaging.Unfortunately this part is no longer available.
Unless you can figure out how to fix the switch to the bracket.
Simon.
Thanks again, Simon. I will have to remove the cover and try to figure how to tape that switch in place if I can. I was considering if I should remove that whole assembly which holds the 3 switches but not sure if I would totally mess things up.
Bernie
Bernie157
#12 Posted : Monday, January 28, 2013 10:39:45 AM(UTC)
Bernie157
Bernie
The microwave oven seems to have quit altogether now. I have order a new, smaller one online and hope to have it tomorrow. They are supposed to take the old one away.
Bernie
2 Pages<12
