pwnoble14
#1 Posted : Monday, January 14, 2013 5:50:32 AM(UTC)
pwnoble14
I have a Gallery Series washer (new in 2005, 13 cycles, two speed motor) that will not fill with enough water to wash large loads of laundry (other cycles work properly). I cannot read the serial numbers since they are located on the inside lid and are not legible.
Can I do anything to change the water level?
Simon / APP Team
#2 Posted : Monday, January 14, 2013 2:14:50 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Was this problem from the beginning or slowly developed?
Try this: drain water completely out, remove the air hose from the pressure switch and blow inside.Reconnect it back and see if that help.
If not - you may need to replace the pressure switch.
Check if there is the part # on the body.
Post the results.
Simon.
Need help to correct water fill on washer (Washer Repair)
by pwnoble14 1/14/2013 5:41:01 AM(UTC)
