I have a Gallery Series washer (new in 2005, 13 cycles, two speed motor) that will not fill with enough water to wash large loads of laundry (other cycles work properly). I cannot read the serial numbers since they are located on the inside lid and are not legible.
Can I do anything to change the water level?
Groups: APP Team
Hi.
Was this problem from the beginning or slowly developed?
Try this: drain water completely out, remove the air hose from the pressure switch and blow inside.Reconnect it back and see if that help. If not - you may need to replace the pressure switch. Check if there is the part # on the body.
Post the results.
Simon.
