Hi! Guys i have a frigidaire of which there was a beeping sound last Friday showing F1, than went away. Now the oven; Bake,Vari Broil and Clean buttons are not working, meaning i can't bake anything as of now, any help. Thanks in advance Modest.
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Hello Denman, I hope you can help! I have a frigidaire es300, and the oven stopped working, so I ordered and installed
Clock/timer Part Number: AP3561834 Made by FRIGIDAIRE Part Details - FRIGIDAIRE Clock/timer, part number: AP3561834Unfortunately, the buttons aren't working right. They are performing different functions. I looked at the repair manual PDF you have, and it's functioning just like the ES200 panel. Did I order the wrong one? (I hope not, my wife will kill me!) Thanks
rianocerous
Did I order the wrong one? Cannot say, I do not work for AppliancePartsPros and the model number you gave (ES300) does not come up. All I can suggest is that you go to the Frigidaire site and check the clock/timer number there. You can then come back to the AppliancePartsPros site and use it to cross reference and see if your model comes up. |
Thanks For your reply. If you could - I have another question.
I think I found the right clock timer - the one you mentioned (turns out my model # is in fact FEFL67DCE).
I plan on ordering it, unless...What's happening is that when we click bake, we hear the relay click, but the element nevr heats up. I assume it's more likely the timer than the element, but could I be wrong? Which is more likely to go out?
correction - i finally found the right part - Part Number: AP4501684 , but the same question still applies. Based on the symptoms (the clock shows the oven on at 350, and trying to preheat, but there is NO HEAT. The broiler however does work) does that sound more like this part, or the element itself?
Thanks so much
rianocerousHere are your parts, includes a wiring diagram Wiring diagram replacement parts for FRIGIDAIRE FEFL67DCE Frigidaire/range | AppliancePartsPros.comBased on the symptoms (the clock shows the oven on at 350, and trying to preheat, but there is NO HEAT. The broiler however does work) does that sound more like this part, or the element itself. I am assuming that you can change the oven set temperature and it is not locked at 350. I would check the bake element first, just because it is easier to do. Unplug the unit. Remove the screw/screws holding the element to the back of the unit. Gently pull it forward. Undo the wire on one side of it. It is a good idea to clip something to the wire so it does not disappear into the back of the unit. Measure it with a meter should be 20 ohms approximately. Here is a manual which may be helpful http://frigidaireservicetips.com/pdfs/477_5.pdfIt is not the greatest as it does cover many units so you have to be careful to be sure you are looking at info for your unit. |
Thanks so much, I'll do a resistance text tomorrow and check
