AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Washer does not get cold water, works with hot only
The washer does not supply cold water. The pipe for cold water is OK. Washing with hot water only. Thanks!
Washer GE mod.# S2100G5WW Stopped working with cold water. The cold water supply pipe is OK. [URL="http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=S2100G5WW"][/URL]
Groups: APP Team
You have been a member since:: 2/12/2012(UTC) Posts: 5,556
Hi. Remove the cold water hose and check if the water goes through it, next check if the screen inside the water valve port is not blocked with debris.Clean if needed. Next open the control panel and with temperature set for COLD/COLD start the washer and check using the multimeter for 120VAC at the water inlet valve coils between T-WR and V-WR. If correct voltage is present - replace the water valve Part number: WH13X10026
Dishwasher Repair
