graffmario
#1 Posted : Friday, January 11, 2013 8:49:26 AM(UTC)
graffmario
The washer does not supply cold water. The pipe for cold water is OK. Washing with hot water only.
Thanks!
graffmario
#2 Posted : Friday, January 11, 2013 8:55:02 AM(UTC)
graffmario
Washer GE mod.#S2100G5WW
Stopped working with cold water. The cold water supply pipe is OK.
[URL="http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=S2100G5WW"][/URL]
Simon / APP Team
#3 Posted : Friday, January 11, 2013 3:00:30 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Remove the cold water hose and check if the water goes through it, next check if the screen inside the water valve port is not blocked with debris.Clean if needed.
Next open the control panel and with temperature set for COLD/COLD start the washer and check using the multimeter
for 120VAC at the water inlet valve coils between T-WR and V-WR.
If correct voltage is present - replace the water valve
Part number: WH13X10026
If not - check the temperature switch contacts 1-3 for continuity. If open - replace it Part number: WH12X10498
If it's closed - replace the timer Part number: WH12X10338
Here are the breakdown diagrams and Controls & Backsplash parts for GE S2100G5WW - AppliancePartsPros.com
Post the results.
Simon.
Guest (5)
