having problems with the dryer if i turn the dryer on an try to hold back the barrel drum from turning it shuts off any little bit of resistance on the barrel drum it will shut the dryer off please help desperate
The Starts And Run For 15 Minutes And Turn Off And Also At The Same Time Breaker Also Turn Off Then We Turn On Braker It Start And Same After Few Minutes It Turn Off So What Is The Main Cause Pl Guide Me
Groups: APP Team
HI.
Please provide the dryer model number. Also you may need to have an electrician check the circuit breaker.
Thank you.
Simon.
