dumbpit
#1 Posted : Thursday, January 10, 2013 9:03:10 PM(UTC)
dumbpit
having problems with the dryer if i turn the dryer on an try to hold back the barrel drum from turning it shuts off any little bit of resistance on the barrel drum it will shut the dryer off please help desperate
#2 Posted : Friday, January 11, 2013 5:21:39 PM(UTC)
Can you describe the problem more detailed please?
Here are the breakdown diagrams and Parts for Magic Chef YG225LV Dryer - AppliancePartsPros.com
patelkeereet
#3 Posted : Monday, June 22, 2015 5:42:37 PM(UTC)
patelkeereet
The Starts And Run For 15 Minutes And Turn Off And Also At The Same Time Breaker Also Turn Off Then We Turn On Braker It Start And Same After Few Minutes It Turn Off So What Is The Main Cause Pl Guide Me
Simon / APP Team
#4 Posted : Tuesday, June 23, 2015 8:53:10 AM(UTC)
Simon / APP Team
Groups: APP Team
HI.
Please provide the dryer model number. Also you may need to have an electrician check the circuit breaker.
Thank you.
Simon.
