danielcastro3669
#1 Posted : Thursday, January 10, 2013 8:18:46 AM(UTC)
danielcastro3669
washer wasn't fully draining, so i pulled the pump out for clean up, found soap scum, and cotton arround the shaft. but after i reinstalled the pump it make a grinding noise when ever water is applyed. any ideas?
Simon / APP Team
#2 Posted : Thursday, January 10, 2013 1:55:17 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the sump for foreign objects, check if you reinstalled everything correctly (the impeller), check if the noise is coming from the motor.
Simon.
danielcastro3669
#3 Posted : Tuesday, January 22, 2013 9:14:16 PM(UTC)
danielcastro3669
thank you. yes there was pieces of glass under the impeller. and the motor was also noisy.i ended up replacing the entire assembly.. worked perfect.. 160 bucks
Simon / APP Team
#4 Posted : Wednesday, January 23, 2013 9:34:59 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
Noisy Pump, Impeller Now Broken? (Dishwasher Repair)
by metman 8/7/2007 1:08:55 PM(UTC)
