washer wasn't fully draining, so i pulled the pump out for clean up, found soap scum, and cotton arround the shaft. but after i reinstalled the pump it make a grinding noise when ever water is applyed. any ideas?
Groups: APP Team
Hi.
Check the sump for foreign objects, check if you reinstalled everything correctly (the impeller), check if the noise is coming from the motor.
Simon.
Originally Posted by: danielcastro3669 washer wasn't fully draining, so i pulled the pump out for clean up, found soap scum, and cotton arround the shaft. but after i reinstalled the pump it make a grinding noise when ever water is applyed. any ideas? thank you. yes there was pieces of glass under the impeller. and the motor was also noisy.i ended up replacing the entire assembly.. worked perfect.. 160 bucks
Groups: APP Team
