tm430
#1 Posted : Wednesday, January 9, 2013 6:54:45 AM(UTC)
tm430
I ran some self diagnostic test and Im not real clear on 2 of them. The first one is on test 07 the results were, #1fresh food top term O fresh , next freash food bottom therm P next Quick chill therm P,next Evap therm P, and the last one Frezzer therm, it has kind of a ? mark, what dose that mean. I also tested the defrost heater test 1-4 and that lit up no problem. Can you explaine to me what that ? mark is, Thank You.
madmaxltd2
#2 Posted : Friday, June 1, 2018 7:46:43 AM(UTC)
madmaxltd2
Does ? mean "Short to 5VDC"????? I have same problem. Tested the thermistto through the motherboard, and the Ohm readings weren't correct according to the temperature/Ohm table. I replaced thermistor, and it didn't do any good.
HOW DO YOU FIX A SHORT TO 5VDC??
RESOLVED: WR55X10942 not running after messing with diagnostic codes (Refrigerator & Freezer Repair)
by rick33 12/12/2021 12:22:21 PM(UTC)
Schematic and tech sheet with diagnostic codes missing (Refrigerator & Freezer Repair)
by PeteClements 3/22/2015 7:15:13 AM(UTC)
Frigidaire Affinity Washer Will Not Start or Display Diagnostic Codes (Washer Repair)
by pwmin 8/5/2014 7:40:09 PM(UTC)
GE Profile refrigerator self diagnostic codes (Refrigerator & Freezer Repair)
by abagai2005 4/28/2012 11:18:37 PM(UTC)
