I ran some self diagnostic test and Im not real clear on 2 of them. The first one is on test 07 the results were, #1fresh food top term O fresh , next freash food bottom therm P next Quick chill therm P,next Evap therm P, and the last one Frezzer therm, it has kind of a ? mark, what dose that mean. I also tested the defrost heater test 1-4 and that lit up no problem. Can you explaine to me what that ? mark is, Thank You.
Groups ready for retrieval: Registered
Originally Posted by: tm430 I ran some self diagnostic test and Im not real clear on 2 of them. The first one is on test 07 the results were, #1fresh food top term O fresh , next freash food bottom therm P next Quick chill therm P,next Evap therm P, and the last one Frezzer therm, it has kind of a ? mark, what dose that mean. I also tested the defrost heater test 1-4 and that lit up no problem. Can you explaine to me what that ? mark is, Thank You. Does ? mean "Short to 5VDC"????? I have same problem. Tested the thermistto through the motherboard, and the Ohm readings weren't correct according to the temperature/Ohm table. I replaced thermistor, and it didn't do any good. HOW DO YOU FIX A SHORT TO 5VDC??
