2 Pages<12
old#7
#11 Posted : Saturday, September 10, 2011 12:16:30 PM(UTC)
old#7
I've got the same problem - drain tube freezes up (a few times now). Kenmore model#106.63182302. What can I do to keep it from freezing up?
kooler
#12 Posted : Sunday, September 11, 2011 11:50:12 AM(UTC)
kooler
There most likely is a restriction in the drain tubing causing condensate to back up in the tube... Another possibility is heavy frost buildup on the evap coil usually experienced by folks who live in extremely humid areas of our country... Typically water will still be dripping off the evap coil at the end of the defrost cycle and freeze in the pan and while trickling down the drain tube eventually freezing closed with subsequent defrost cycles... One trick I've used is a short bare piece of copper wire hung or coiled around the defrost heater and left dangling inside the drain tube... Of course one has to be careful if the heater is a glass type and you wouldn't want to clamp this wire too tight around the metal tubular heaters either... It can damage those types also... Good luck - cheers kooler
cockroach
#13 Posted : Sunday, September 18, 2011 6:51:39 PM(UTC)
cockroach
Gene do you have diagrams for a whirlpool model# ET1CHMXKB06 I am having problems with water in my fridge sometimes it freezes.One day I heard a clunk and then it started to run alot and is constantly draining water inside.Does mine have the same setup as the ET1CHMKQ02 as I see you sent one other person with the same problem?Thanks for your time,Jack
diskwzrd
#14 Posted : Wednesday, May 15, 2013 11:11:30 AM(UTC)
diskwzrd
I have 2 Kenmores doing the same thing right now. Any assistance in locating a diagram for these to make sure I am looking in the right place would be great.
Model #:
106.61289102
106.64259400
THANKS!!!
Freezer bottom lined with ice, water leaking into refrigerator (Refrigerator & Freezer Repair)
by Skay 5/8/2013 1:33:41 PM(UTC)
Water leaking into refrigerator compartment (Refrigerator & Freezer Repair)
by cw.lewis 7/19/2007 7:51:38 PM(UTC)
2 Pages<12
