balm
#1 Posted : Tuesday, September 29, 2009 11:05:33 AM(UTC)
balm
The window glass on my upper oven haws recently broken. I have ordered the new part from Dacor(twice) and confirmed that the Model # is correct.
The part which includes both the inner and outer windows, gasket, and metal frame is slightly(maybe 1/16") too large for the opening and will not slide into place. I do not want to force it as the glass is tempered and may shatter. Are there any tricks or a special Dacor tool that will help me insert this frame without resorting to grinding the inner edge of the oven door?
Thank You
Dacor Double Wall Oven (Oven Repair (including Ranges and Cooktops))
by zell66 10/14/2015 7:16:13 AM(UTC)
Dacor Double Wall Oven-replace lower oven relay board (Oven Repair (including Ranges and Cooktops))
by CatsR 12/27/2010 10:56:52 AM(UTC)
dacor double wall oven lite inop (Oven Repair (including Ranges and Cooktops))
by cfilice 11/13/2008 5:38:30 PM(UTC)
