Bunk2
#1 Posted : Wednesday, January 2, 2013 1:18:25 PM(UTC)
Bunk2
Freezer has a stopped up drain and leaks into the refrigerator below. The refrigerator / freezer is about 10 years old. The freezer does contain an ice maker. Solutions that I have seen on utube and other videos do not show the exact configuration of the freezer area that I have. For example, all solutions show the freezer bottom or back can be removed with removing two screws. I have no bottom shelf to remove. The back looks like it could be removed If I knew how to do it, considering the ice maker must also be removed.
Thanks, Bunk
Bunk2
#2 Posted : Wednesday, January 2, 2013 1:20:34 PM(UTC)
Bunk2
Thanks, Bunk
Additional Info. Serial Number er1830777
Bunk2
#3 Posted : Wednesday, January 2, 2013 1:22:46 PM(UTC)
Bunk2
Model Number is er2chmxpl00
