Freezer has a stopped up drain and leaks into the refrigerator below. The refrigerator / freezer is about 10 years old. The freezer does contain an ice maker. Solutions that I have seen on utube and other videos do not show the exact configuration of the freezer area that I have. For example, all solutions show the freezer bottom or back can be removed with removing two screws. I have no bottom shelf to remove. The back looks like it could be removed If I knew how to do it, considering the ice maker must also be removed.
Thanks, Bunk
Originally Posted by: Bunk2 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Freezer has a stopped up drain and leaks into the refrigerator below. The refrigerator / freezer is about 10 years old. The freezer does contain an ice maker. Solutions that I have seen on utube and other videos do not show the exact configuration of the freezer area that I have. For example, all solutions show the freezer bottom or back can be removed with removing two screws. I have no bottom shelf to remove. The back looks like it could be removed If I knew how to do it, considering the ice maker must also be removed.
Thanks, Bunk Additional Info. Serial Number er1830777
Originally Posted by: Bunk2 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Additional Info. Serial Number er1830777 Model Number is er2chmxpl00
