d.porter
#1 Posted : Thursday, January 31, 2008 8:45:23 AM(UTC)
d.porter
Oven lights do not come on when oven door opened. The lights do come on when using the external switch under the back panel.
Question: Where is the door switch located?? Could you also give me directions on how to access the switch. thx.,
#2 Posted : Thursday, January 31, 2008 2:18:30 PM(UTC)
Is the model number you posted American or Canadian?
If it's American, I need you to verify and repost it.
d.porter
#3 Posted : Thursday, January 31, 2008 2:47:48 PM(UTC)
d.porter
Gene: This is a Canadian model as far as I know.. Interesting enough, after several days , the oven light just came on once when I opened the door of the oven.. I am suspecting a loose or burned connection but do not know how to access the oven switch to diagnose the problem..
#4 Posted : Thursday, January 31, 2008 3:43:31 PM(UTC)
Unfortunately I'm not able to look up a Canadian models.
The light switch could be a part of the door latch or it could be under a door hinge on side of the oven.
d.porter
#5 Posted : Friday, February 1, 2008 7:59:16 AM(UTC)
d.porter
Gene: thank you for the information.
#6 Posted : Friday, February 1, 2008 8:29:25 AM(UTC)
Keep me updated, please.
d.porter
#7 Posted : Friday, February 8, 2008 12:41:14 PM(UTC)
d.porter
Gene: I am unable to determine the location of the switch that activates the oven lights when the oven door is open... I believe it must be by the hinge but have no idea how to get side panels off the stove.. it appears that you have to take the entire stove apart.. So until I get that figured out I will not be able to go any further with this problem.. Doug
#8 Posted : Friday, February 8, 2008 12:50:28 PM(UTC)
Hi Doug,
I would recommend to follow the wires from the light socket.
d.porter
#9 Posted : Friday, February 8, 2008 3:05:15 PM(UTC)
d.porter
Gene: thanks for the tip... I will do that but it will probably a few days before I can get to that... Thx for your feedback.. Doug
