Jeffo
#1 Posted : Thursday, January 31, 2008 4:15:10 AM(UTC)
Jeffo
I overfilled my 7 year old washing machine last night and I noticed later that it sounded like it was struggling; then I noticed that it smelled hot. I stopped it, emptied most of the clothing out, and resumed. It seemed to work fine. When I put in the clothing I had removed to rewash it stopped again (I admit there was still a lot in this second load); I did not smell the hot smell, though. I stopped it, unplugged it, left it unplugged for over 30 minutes, then tried it again; just to empty the water out though. I did not have clothing in it. It still clicked. I left it off all night, unplugged, and tried again. It ran for maybe 20 to 30 seconds this morning sounding like it should. I thought it was okay, but then it started clicking again. Is the motor burned out? Thanks!
#2 Posted : Thursday, January 31, 2008 5:50:09 AM(UTC)
It's common for the low speed winding to burn out on the motor, you might want to run it on high speed only to see if it's ok there, otherwise= new motor time.
Jeffo
#3 Posted : Thursday, January 31, 2008 5:52:25 AM(UTC)
Jeffo
Thank you- any idea how much a new motor will cost, roughly (of course). Also, I guess we could just always run it on high speed if it is just the low speed that is burned out? Or would that be a problem? Thank you again!
#4 Posted : Thursday, January 31, 2008 7:18:37 AM(UTC)
A new motor comes as a kit, around $300, money better spent on a new washer, like a Whirlpool direct drive.
For your model # maybe less for the exact one.
