Laynechain
#1 Posted : Thursday, January 31, 2008 3:35:29 AM(UTC)
Laynechain
Hi, I need help!!!
I have an old 1979 Litton Micromatic Microwave Range(electric 230v)
I ran the self clean option and it didn't turn off when it was supposed to. So I did it manually.
The oven wouldn't work.(The stove top did). I noticed the selection switch smoking. So, I repaired the Oven switch(one that selects bake,broil,clean,time bake etc..). I also repaired the temp. switch(warm,200,250.broil,etc.). All is well (the oven and stove works)except
the light that lights up indicating the oven is on does not light up.(checked it to see if it was blown it's not)and the the temp light stays on until the temp(that it is set to) is reached even when the oven isn't on( when I turn it all the way down to warm). So I have a oven on indicating light that won't illuminate when on and a temp light that won't go off unless the oven is on and it reaches the temp. it's set for.
I unplugged it after using it(the oven). I'm concerned that the temp switch light has power going to it when it is on and don't want a fire.
I have electrical experience and everything seems ok. wires etc... I don't have a schematic for this oven to help though.
P.S. The contacts on the selection switch the rivet was loose so it was slipping down. So, I fixed that and the temp selection switch was fine. I just cleaned it up.
Any help would be greatly appreciated. (We are really tight on funds and I would like to fix this one and FEEL SAFE.)
Thank you for your time and kindness,
John
#2 Posted : Thursday, January 31, 2008 2:15:19 PM(UTC)
Hi John,
Post the complete model number of the unit. Only the model number might help to find the schematic.
Laynechain
#3 Posted : Thursday, January 31, 2008 6:13:24 PM(UTC)
Laynechain
Litton Micromatic Microwave range 230v
Model # 631
Serial # 2971
Ah! Orange County. I was born and raised in Buena Park,CA. Been in the North East for 21 years. Still can't get used to the winters...
Thanks Gene for your time and help.
#4 Posted : Thursday, January 31, 2008 6:52:27 PM(UTC)
Hi John,
Unfortunately I was not able to find the schematic for your oven due to age of the unit. Maybe somebody else on the forum can help you better.
P.S. Check the bottom drawer and the space under the range - the schematic might be there.
