jathwon
#1 Posted : Sunday, December 30, 2012 2:09:33 PM(UTC)
jathwon
The power is on at the junction box. Following advice in the forums, I have replaced the 'Control panel' as well as the 'Electronic panel' purchased from this site. It still does not power on. My next thought is it may be the 'Thermal fuse' that did not come with the 'Electronic panel' or the door switch. Any thoughts?
#2 Posted : Tuesday, January 1, 2013 2:10:41 AM(UTC)
Could be either part but the fuse is more likely.
I would get e multimeter and check it for resistance. Should be 0 ohms.
If it is blown be sure to use the new harness that comes with it.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
No power to dishwasher (Dishwasher Repair)
by Aziemann 3/25/2009 7:45:12 AM(UTC)
