Davejb
#1 Posted : Thursday, December 27, 2012 8:13:20 AM(UTC)
Davejb
Customer (wife) says went badly out of balance, ran "too" long. Then would agaitate but no water. Apply 110 AC to water valve solenoids, both (H & C)work OK. Try again, agitate but still no water. Try again several times, then won't even agitate, and still no water.
What to do?
Thx
Dave
PS: BTW, what is 2 wire fitting in water valve outlet hose?
Thx again
djb
Davejb
#2 Posted : Thursday, December 27, 2012 11:18:44 AM(UTC)
Davejb
What to do?
Thx
Dave
Thx again
djb
Posted on wrong site - sorry about that - Will repost on the right one :-)
Dave
Simon / APP Team
#3 Posted : Thursday, December 27, 2012 11:42:38 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Locate the pressure switch inside the control panel, see if the air hose is attached, then check the continuity between 2 BRN and 3 TAN/BLK contacts.If you have continuity - replace the switch. If not - blow into the air hose to clear the possible restriction in the pressure dome at the outer tub. If you not getting positive result - then most likely it's a bad timer Part number: 134173100
Here are the breakdown diagrams and Control / Panel parts for Frigidaire GLWS1749AS4 - AppliancePartsPros.com
The part with 2 BLK wires you asked about is the thermistor, sensing the water temperature.
Simon.
Davejb
#4 Posted : Thursday, December 27, 2012 5:04:18 PM(UTC)
Davejb
Thanks Simon - much appreciated
Simon / APP Team
#5 Posted : Thursday, December 27, 2012 5:24:53 PM(UTC)
Simon / APP Team
Groups: APP Team
My pleasure.
Simon.
