Customer (wife) says went badly out of balance, ran "too" long. Then would agaitate but no water. Apply 110 AC to water valve solenoids, both (H & C)work OK. Try again, agitate but still no water. Try again several times, then won't even agitate, and still no water.
What to do? Thx Dave
PS: BTW, what is 2 wire fitting in water valve outlet hose?
Thx again djb
Originally Posted by: Davejb  Customer (wife) says went badly out of balance, ran "too" long. Then would agaitate but no water. Apply 110 AC to water valve solenoids, both (H & C)work OK. Try again, agitate but still no water. Try again several times, then won't even agitate, and still no water.
Thx again djb Posted on wrong site - sorry about that - Will repost on the right one :-) Dave
Groups: APP Team
Hi. Locate the pressure switch inside the control panel, see if the air hose is attached, then check the continuity between 2 BRN and 3 TAN/BLK contacts.If you have continuity - replace the switch. If not - blow into the air hose to clear the possible restriction in the pressure dome at the outer tub. If you not getting positive result - then most likely it's a bad timer Part number: 134173100
Thanks Simon - much appreciated
Groups: APP Team
