PCG58
#1 Posted : Monday, September 28, 2009 12:25:02 PM(UTC)
PCG58
My Dishwasher is not working. When I start the cycle the LCD panel shows that the cylce starts but u never hear the water swishing around, after a while. When I open it everything is hot & foggy and sounds like its drying but nothing is wet!!! Then there is very little water @ the bottom. Which I then have to drain, so I press the cancel button and you can hear it draining.
Please help!!! I did order a part from your company, my plumber thought was the problem, but it was in fact not. (water inlet valve assembly) Part# Ap3178609 (8531669)
After they replaced the part the same thing happened. It's not washing, they is no sign of water, except @ the very bottom.:(
#2 Posted : Tuesday, September 29, 2009 11:51:31 AM(UTC)
Sounds like the wash and drain pumps are not working. Remove the toe panel and check for 120 VAC to the wash pump motor while the control calls for wash.
Here is the Tech sheet for your dishwasher.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDS01IJBL1 | AppliancePartsPros.com
KA dishwasher doesn't wash. Fills and drains (Dishwasher Repair)
by dishdr 8/18/2016 7:50:35 AM(UTC)
Old GE Dishwasher doesn't wash or drain (Dishwasher Repair)
by Jeffers 10/10/2010 9:04:57 PM(UTC)
kenmore dishwasher doesn't wash (Dishwasher Repair)
by dbonet 3/17/2008 3:51:16 PM(UTC)
