easton01
#1 Posted : Monday, December 17, 2012 5:26:55 PM(UTC)
easton01
My Kenmore elite slide in gas oven - the oven light won't shut off. Could it be the control pad sensor?
#2 Posted : Tuesday, December 18, 2012 1:55:22 PM(UTC)
Does it beep when you push it?
If it does then more likely the problem is a bad control board.
If it does not then the keypad,which is a part of the control panel has to be replaced.
- The control board Part number: 316418782
- The control panel Part number: 318335810
easton01
#3 Posted : Wednesday, December 19, 2012 11:32:58 AM(UTC)
easton01
there is no beep when I try to shut off the light. Is there anyway I can just remove the light bulb?
#4 Posted : Wednesday, December 19, 2012 12:20:03 PM(UTC)
Yes, you can do it. Just follow the instructions in the Owners manual.
