Microwave stopped doing its stuff.
Light come on when door is opened, timer comes on and counts down when start is pushed, but the light inside goes out and nothing happens, except for the timer counting down the seconds.
Thanks in advance for any help. A parts diagram would be wonderful!
Groups: APP Team
Hi.
Based on the info you provided you need to check the door switches (upper and lower interlock). Unfortunately your model number doesn't come up in the search. If you will be able to find the bad switch and post the picture of it, I'll find you the replacement.
Simon.
