AZWY35
#1 Posted : 12 years ago
AZWY35
Our Oven recently quit heating, none of the elements will heat in the oven. Cook Top works fine. Replaced Electronic Control Bd and Sensor probe. When plugged in Control Bd lights up and Touch Pad works fine. Checked DMB Relay, it is fine. Strange, shows 110v to Broiler elements and Convection Element on both sides, but not 220 across leads. L1 Bi metal NC to Control Bd. OK, Oven Fan NO Bi metal OK! Are there any other fuses that are not visible. Oven has hidden bottom baking element!
Stymied in AZ!!!!!
#2 Posted : 12 years ago
Parts for Whirlpool KESC307HBT1 Range - AppliancePartsPros.com
See the attachment for the tech sheet
I am assuming that you mean the DLB relay not the DMB.
[COLOR="Blue"]Strange, shows 110v to Broiler elements and Convection Element on both sides, but not 220 across leads.[/COLOR]
With the DLB relay closed this would be normal. I am assuming you are referenced to Neutral. You will see the L2 voltage at both sides of the elements. The element is just a resistance so the voltage will feed through it.
For some reason the element is not getting the L1 voltage.
If it was OK then you would also see 120 volts on the L1 side of the element but it is 190 degrees out of phase with the L2 voltage so you get 240 across the element and it heats up.
I am assuming that this was a live test so the DLB relay was closed and the voltage was at all the element at the same time (L2 side). If this is not the case and you saw the voltage at individual elements re: only voltage at inner broil element when it econo broil. Then the problem is on the L2 side.
[COLOR="Blue"]
L1 Bi metal NC to Control Bd. OK, Oven Fan NO Bi metal OK! Are there any other fuses that are not visible. Oven has hidden bottom baking element![/COLOR]
As far as I know you have checked everything.
When you checked the thermal cut-out did you use the mist sensitive meter scale to be sure it is 0 ohms. Also did you disconnect one side of it. This is important so that you do not read an alternate/parallel circuit path.
Does the unit stay in preheat or does it show ready?
Unplug the unit and check the resistance of the wires/connectors of the power to the board and elements.
Here is my theory on the above. If you have a bad connection then this is a resistance. As long as you are not pulling any amperage everything will look normal. Lets say this resistance is 1000 ohms. When the elements call for power all the voltage is dropped across this resistance and it would limit the current to a 0.24 amps.
There is always the possibility that you received a defective control board.
File Attachment(s):
KESC307H.pdf (166kb) downloaded 1 time(s).
AZWY35
#3 Posted : 12 years ago
AZWY35
Had Dino's Appliance Rpr. out today --excellent Co in PhX. Turns out it was the inline fuse on the back of the oven! The wiring diagram had it noted as a bi metal fuse --- replaced with a bi metal fuse, and bingo -- fixed!
AZWY35
Oven Will not heat to temp. (Oven Repair (including Ranges and Cooktops))
by rtmeek 3 years ago
Frigidaire FEFL79HQA Oven Will Not Heat (Broil or Bake) (Oven Repair (including Ranges and Cooktops))
by Allen_M 3 years ago
Frigidaire - Oven will not heat up but burners work (Oven Repair (including Ranges and Cooktops))
by JohnGuerra 5 years ago
Frigidaire gas oven will not heat (Oven Repair (including Ranges and Cooktops))
by HHG 6 years ago
GE Profile Oven will not heat past 100, broiler works (Oven Repair (including Ranges and Cooktops))
by maribernj 9 years ago
Oven will not heat (Oven Repair (including Ranges and Cooktops))
by couldcareless 9 years ago
by davidwhop 11 years ago
Double Wall Oven will not heat up (Oven Repair (including Ranges and Cooktops))
by jwmingus 11 years ago
Frigidaire Left oven will not heat either element (Oven Repair (including Ranges and Cooktops))
by morang 12 years ago
Thermador sc302t top oven will not heat (Oven Repair (including Ranges and Cooktops))
by bnastasi 12 years ago
Lower and Upper Oven will not heat (Oven Repair (including Ranges and Cooktops))
by Igmike 12 years ago
My Oven will not heat up on bake (Oven Repair (including Ranges and Cooktops))
by missy79 12 years ago
Electrolux dual fuel range oven will not heat (Oven Repair (including Ranges and Cooktops))
by p.andrew 12 years ago
by Pjcibulski 12 years ago
Oven Will Not Heat (Oven Repair (including Ranges and Cooktops))
by badams1214 12 years ago
