I can not get the halogen bulb out to replace it. It is protruding to little to grasp and pull out. Any ideas how to get it out safely? No help in the manual found and no help from KitchenAid on the phone. Please, help.
The above model number is for the bulb, WPL4452164.
The model number for the KitchenAid built-in oven/microwave is
KEMS307DWH6.
double check that model number
that's better
Originally Posted by: RegUS_PatOff  double check that model number
that's better The model # is KEMS307DWH6. The halogen bulb is visible from the inside of the microwave and does not have a cover. Is there maybe a special device to pull it out without breaking it?
