PTJT5
#1 Posted : Sunday, September 27, 2009 8:55:52 AM(UTC)
PTJT5
My washer is leaving clothes wet. It sounds like it drains and it spins slowly but doesnt spin fast and will than shut off. Can anyone help?
sidfink43
#2 Posted : Monday, September 28, 2009 10:35:18 AM(UTC)
sidfink43
Take off the front access panel which should give you access to the pump and drain hoses. Take off the hoses and make sure there is nothing obstructing the pump or hoses, clean everything out and try again.
If this does not solve the problem there should be tech notes inside the lower panel which will show you how to troubleshoot the machine.
Water is left in washer, door is locked cannot open, does not drain, clothes still wet (Washer Repair)
by Guest 12/4/2022 11:52:36 AM(UTC)
kenmore he2 clothes still wet (Washer Repair)
by ldenorio 2/9/2020 2:55:08 PM(UTC)
Crosley Washer (Whirlpool) not spinning fast enough, clothes still wet (Washer Repair)
by Cajun Girl 12/5/2018 12:12:13 PM(UTC)
clothes still wet after cycle spin (Washer Repair)
by biho 12/25/2015 8:35:07 PM(UTC)
Spins but clothes still wet (Washer Repair)
by tom rosser 8/11/2014 10:59:53 AM(UTC)
Maytag top load - drains & spins but clothes still wet (Washer Repair)
by Liz459 3/24/2013 4:26:14 PM(UTC)
clothes still wet after 1st spin cycle but dry after 2nd spin cycle (Washer Repair)
by sscaduto 11/10/2012 1:28:37 PM(UTC)
Clothes still wet after spin cycle (Washer Repair)
by gbdad10 3/31/2012 3:35:25 PM(UTC)
Clothes still wet after spin (Washer Repair)
by Ranger25 7/24/2011 2:43:22 PM(UTC)
Clothes still wet (Washer Repair)
by davjulcos 3/10/2011 8:06:42 AM(UTC)
Maytag stackable SG7800 clothes still wet at end (Washer Repair)
by smr277 10/9/2010 10:12:31 PM(UTC)
Clothes still WET after final spin (Washer Repair)
by HandyHubby1963 7/2/2010 7:00:52 AM(UTC)
by Rheinking 4/30/2010 11:19:45 AM(UTC)
by pnowacki 1/15/2010 6:38:18 PM(UTC)
Neptune washer spins and pump working but clothes still wet (Washer Repair)
by lanehi 10/25/2009 4:07:25 AM(UTC)
