My washer is leaving clothes wet. It sounds like it drains and it spins slowly but doesnt spin fast and will than shut off. Can anyone help?
Take off the front access panel which should give you access to the pump and drain hoses. Take off the hoses and make sure there is nothing obstructing the pump or hoses, clean everything out and try again.
If this does not solve the problem there should be tech notes inside the lower panel which will show you how to troubleshoot the machine.
