My estate washer is about 7-8 yrs old and yesterday I was running a medium load through when it was about to start the spin cycle, it just sat there and made a loud grinding and wouldn't spin. I'd like to try and fix it because of the space that the washer has to fit though I just can't find a small enough replacement for it. I'm used to fixing computers though, not washers...
Groups: Expert
Does it fill, agitate and drain ok?
Eric
Not sure about the agitator... but it did drain ok after the rinse cycle. Should I plug it back in and try to start it filling and check the agitator? Thanks for the quick reply!
OK... I restarted a cycle and it fills and drains no problem, but at the start of the wash cycle the agitator barely moves - it moves a tiny bit but mostly grinding.
Groups: Expert
Sure enough... that little plastic piece was broken. Thanks!
