mattcanfixit
#1 Posted : Sunday, December 2, 2012 4:37:59 AM(UTC)
mattcanfixit
My estate washer is about 7-8 yrs old and yesterday I was running a medium load through when it was about to start the spin cycle, it just sat there and made a loud grinding and wouldn't spin. I'd like to try and fix it because of the space that the washer has to fit though I just can't find a small enough replacement for it. I'm used to fixing computers though, not washers...
fairbank56
#2 Posted : Sunday, December 2, 2012 6:11:44 AM(UTC)
fairbank56
Groups: Expert
Does it fill, agitate and drain ok?
Eric
mattcanfixit
#3 Posted : Sunday, December 2, 2012 6:55:03 AM(UTC)
mattcanfixit
Not sure about the agitator... but it did drain ok after the rinse cycle. Should I plug it back in and try to start it filling and check the agitator? Thanks for the quick reply!
mattcanfixit
#4 Posted : Sunday, December 2, 2012 7:07:06 AM(UTC)
mattcanfixit
OK... I restarted a cycle and it fills and drains no problem, but at the start of the wash cycle the agitator barely moves - it moves a tiny bit but mostly grinding.
fairbank56
#5 Posted : Sunday, December 2, 2012 8:12:29 AM(UTC)
fairbank56
Groups: Expert
Sounds like the drive coupler between the motor and gearcase. You'll need to open the control panel and remove the washer cabinet. Then remove the drain pump from the motor and remove the motor.
Washer Motor Coupling (part #285753A) - How To Replace - YouTube
Eric
mattcanfixit
#6 Posted : Sunday, December 2, 2012 8:52:23 AM(UTC)
mattcanfixit
Sure enough... that little plastic piece was broken. Thanks!
