when I close the door there is a constant relay clinking sound from the electronic unit every half a second but nothing starts, light are operational on the push panel. Could you tell me what part you think I need to replace? Thanks
Groups: APP Team
Hi.
Most likely it's a bad control module. For the correct part number please check the last two digits after the slash in the model number. Should be two numbers.
Simon.
the last two numbers are 11 Could you tell me how much is the part and if its not the problem can I return the part. Thanks
Groups: APP Team
Hi. This is the control module Part number: 481055
You can return any part even if they been installed. Simon.
