Areg
#1 Posted : Thursday, November 29, 2012 7:36:41 AM(UTC)
Areg
when I close the door there is a constant relay clinking sound from the electronic unit every half a second but nothing starts, light are operational on the push panel. Could you tell me what part you think I need to replace? Thanks
Simon / APP Team
#2 Posted : Thursday, November 29, 2012 8:17:04 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely it's a bad control module.
For the correct part number please check the last two digits after the slash in the model number. Should be two numbers.
Simon.
Areg
#3 Posted : Thursday, November 29, 2012 2:31:22 PM(UTC)
Areg
the last two numbers are 11
Could you tell me how much is the part and if its not the problem can I return the part.
Simon / APP Team
#4 Posted : Thursday, November 29, 2012 3:14:13 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
This is the control module Part number: 481055
Part number: 481055
You can return any part even if they been installed.
Simon.
