CNELSONCOOPER
#1 Posted : Wednesday, November 28, 2012 11:28:40 AM(UTC)
CNELSONCOOPER
My Whirpool washer has gone dead. It had been having an issue for about 2 years. Without any input, it would turn on itself, no cycling, just power on showing 44 minutes as a cycle time. I could sometimes turn it off, sometimes not. When I could not, I would unplug it for a day, plug it back in and it would usually be ok. I assumed it was the membrane switches shorting out, but was not sure. Yesterday, when I selected a cycle it would not come on. As I contined to select a cycle, it would occasionaly power on but then turn off. After a few dozen attempts at this, it will no longer even come on temporarily. My question is, what part do I replace? My first assumption is that it is the control panel that contains the membrane switches, but I also see three other possible parts, electronic control board, motor control board (not likely), and switch-WI. I want to avoid hit and miss parts replacement since most of these parts are quite expensive and replacing them is close to just buying a new machine. BTW, I havn't checked the lid switch yet, but suspect that is not the issue given the other symptons. I am leaning toward the conrol panel.
CNELSONCOOPER
#2 Posted : Friday, November 30, 2012 3:53:54 PM(UTC)
CNELSONCOOPER
Checked the lid switch, no problem. Found this service manual on line, checked the control panel and found most of the switches no longer work. Will order a control panel.
https://secured.whirlpool.com/Servic...LE/8178010.pdf
CNELSONCOOPER
#3 Posted : Wednesday, December 5, 2012 10:57:53 AM(UTC)
CNELSONCOOPER
New control panel arrived, installed in a few minutes and problem is now solved. The issue was as I first guessed, the control panel. These type of switches have been around quite a while but reliability has always been an issue with them. The secret was finding in this repair forum a pointer to the diagnostic manual. It confirmed what I suspected.
Dead Washer (Washer Repair)
by MMMM 1/15/2016 10:51:07 AM(UTC)
Dead washer (Washer Repair)
by Matthewryan 7/26/2012 6:39:30 PM(UTC)
by PepeCo 2/8/2012 7:13:27 PM(UTC)
by elizaine729 7/10/2011 9:12:22 AM(UTC)
dead washer (Washer Repair)
by daddy1 10/29/2010 5:42:19 AM(UTC)
