Matthewryan
#1 Posted : Thursday, July 26, 2012 6:39:30 PM(UTC)
Matthewryan
Got a washer from friends, got it home and it's dead. No lights what so ever. Checked everything, plug, breaker, etc and it won't light up. Worked for them, it sat in their garage a while but that shouldn't matter. Damage from moving? How do I get it to work?
sidfink43
#2 Posted : Saturday, July 28, 2012 4:02:53 PM(UTC)
sidfink43
Use a meter to check that current is getting to the main board. If you click on your model number you will see exploded views of your machine and a wiring diagram.
Also, inside the lower service panel should be a tech sheet. Do some testing but it sounds as if you main board is fried, don't know why, sitting should not have harmed it.
Dead Washer (Washer Repair)
by MMMM 1/15/2016 10:51:07 AM(UTC)
by CNELSONCOOPER 11/28/2012 11:28:40 AM(UTC)
by PepeCo 2/8/2012 7:13:27 PM(UTC)
Dead washer (Washer Repair)
by elizaine729 7/10/2011 9:12:22 AM(UTC)
dead washer (Washer Repair)
by daddy1 10/29/2010 5:42:19 AM(UTC)
