andrewdelaware
#1 Posted : Wednesday, November 28, 2012 6:16:06 AM(UTC)
andrewdelaware
I have this Jenn Air range, stopped working suddenly. The burners still work, but the control pad does not work (no beeps) and the display is blank, thus the oven won't work as well. Repair guy says it needs a new control pad. My question is, will a bad control pad cause the display to be off as well? I see the control pad is a seperate part than the control board that has the display with it. I am thinking of ordering a new control pad myself but do not want to waste the money if the control board is toast also.
#2 Posted : Thursday, November 29, 2012 2:23:43 AM(UTC)
http://www.appliancepartspros.c...ch.aspx?model=JES9800AAW
I would check the power first.
Could be that you have lost Neutral.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If power is OK then I agree with you that it is more likely that the control board/clock (item 5 in the Control Panel section) is toast.
