Soap dispenser not opening during cycle...I have checked prior posts and replaced wax motor but door still won't open. I opened it again and it seems that I can't even open door while trying to manually push slide to left to release pin on the latch...slide seems worn...is this possible and can I replace just the slide or do I need the whole assembly? Thanks
THIS FORUM IS DEAD!!!!!!! |
Thanks....took it all apart again & cleaned it up...think soap was causing problem...door now works but will get new parts & replace em....thanks for your help........
You are welcome
Glad to help out. |
