Angelicas
#1 Posted : 18 years ago
Angelicas
An older top freezer bottom refrig model is not cooling in the refrig, the freezer fan blows cool but doesn't freeze any more. I had a service tech come out and said the defrost timer was bad. He reset it and it worked great for 8 months. It happened again and I unplugged the refrig and turned the timer again but it is not cooling now. The compressor and inside fan kicks on like normal it just won't cool.
jdman
#2 Posted : 18 years ago
jdman
Could be the defrost heater is not shutting off due to bad timer, low on refrigerant of extremely dirty coils and condensing fan motor
Angelicas
#3 Posted : 18 years ago
Angelicas
Thanks I never thought about the heater being stuck on, that makes more sence:o
