On this model of stove there are about 15 rubbery push buttons on the control panel. One of these, start button, activates the oven. It no longer works when I press it. Is this just a switch problem and I should replace that button? Or could it be something else? Any advice would be appreciated.
Originally Posted by: Gene  Thanks Gene. I took apart the control panel to take a look and saw the printed circuit that the Start button touches. The rubber button itself does move freely so I guess that was not the problem. When I put it back together, for some reason, the button was working. I also had turned off the circuit breaker to the stove while I was doing this. Can you figure out why it would start to work again?
It could be as simple as a dust inside. Sometime reseting the power helps too. Hopefully it will last.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hello yes I was seeing if this issue can be fixed I have a Whirlpool stove and the start button which is a push in pushed all the way in help please
