colejster
#1 Posted : Saturday, November 24, 2012 7:41:00 AM(UTC)
colejster
On this model of stove there are about 15 rubbery push buttons on the control panel. One of these, start button, activates the oven. It no longer works when I press it. Is this just a switch problem and I should replace that button? Or could it be something else?
Any advice would be appreciated.
#2 Posted : Saturday, November 24, 2012 7:00:46 PM(UTC)
If this button is moving freely in and out then the problem is a bad control board. Unfortunately this part is no longer available.
Here are the breakdown diagrams and Parts for Whirlpool GJP84802 Range - AppliancePartsPros.com
colejster
#3 Posted : Sunday, November 25, 2012 3:42:37 AM(UTC)
colejster
Thanks Gene. I took apart the control panel to take a look and saw the printed circuit that the Start button touches. The rubber button itself does move freely so I guess that was not the problem. When I put it back together, for some reason, the button was working. I also had turned off the circuit breaker to the stove while I was doing this.
Can you figure out why it would start to work again?
#4 Posted : Monday, November 26, 2012 1:01:13 PM(UTC)
It could be as simple as a dust inside. Sometime reseting the power helps too. Hopefully it will last.
Guest
#5 Posted : Thursday, December 1, 2022 2:26:43 PM(UTC)
Guest
Rank: Guest
United States
Hello yes I was seeing if this issue can be fixed I have a Whirlpool stove and the start button which is a push in pushed all the way in help please
Guest (4)
