hsid
#1 Posted : Tuesday, November 20, 2012 9:31:44 AM(UTC)
hsid
Small amount of Water is leaking from the solenoid area when the dishwasher cycles. Any repair advice is appreciated.
Simon / APP Team
#2 Posted : Tuesday, November 20, 2012 10:24:36 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely it's the leaking flapper shaft seal Part number: WD8X181
Use some silicone lubricant when replacing it.
Here are the breakdown diagrams and 03-Motor-Pump Mechanism parts for GE HDA2000Z05WH - AppliancePartsPros.com
Post the results.
Simon.
hsid
#3 Posted : Sunday, November 25, 2012 5:40:37 AM(UTC)
hsid
Purchased flapper shaft seal and push on nut. Silicone lubricant (what kind, where and how to apply) and repair instructions is appreciated.
Simon / APP Team
#4 Posted : Monday, November 26, 2012 1:43:13 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Best to remove the dishwasher from the cabinet.Unplug it first.
The shaft seal is located behind the solenoid bracket. memorize the order in which to reassemble everything.
Use a needle to take the old seal out.
A silicone lubricant is available at any automotive stores.Clean the opening before applying the lubricant.
Fill up the cavity with lubricant, install the new seal and solenoid bracket.
Simon.
