bnentrup
#1 Posted : Monday, November 19, 2012 3:12:18 PM(UTC)
bnentrup
I have a smaller under-counter refrigerator, that has a Temp controller/thermostat unit --- and when first plugging in the unit, it powers on cold and holds temp. If I adjust the temp and turn the control to a certain point-- it shuts off the refrigerator. It will NOT cycle back on regardless of how long I wait or where I turn the control from there.
Instead of me saying I think it is 'this' -- what should I check? It so happens that I have 4-of these units with the same issue as this that I bought at an auction. My goal is to turn them into kegerators, but have to be able to set the temp to specific temp first.
Thanks!
Simon / APP Team
#2 Posted : Monday, November 19, 2012 6:23:15 PM(UTC)
Simon / APP Team
Groups: APP Team
HI.
Based on the info you provided it's a bad cold control. You can test it for continuity or install the jumper wire and check if it'll kick in.
The cold control kit Part number: 2923-S
Part number: 					2923-S
Post the results.
Simon.
bnentrup
#3 Posted : Monday, November 19, 2012 6:27:27 PM(UTC)
bnentrup
Wow,
you are right on! I jump the controller, and walla! IT fires right up. I have an ice maker too that is about 9-yrs old, and I bet...... same thing! I will purchase a couple of control units, and post the results once the swap is complete.
Simon / APP Team
#4 Posted : Tuesday, November 20, 2012 8:30:16 AM(UTC)
Simon / APP Team
Groups: APP Team
Good luck.
Simon.
